305 to 350
Car: 91 camaro rs
Engine: 355
305 to 350
I'm 15 and am looking to get a 350 to rebuild and swap out with my slow 305. I wanted to get some ideas on what parts I should get and some specs I should use. It is a daily driver but I want to get as much horsepower out of it as I can. I'm leaning towards swapping to carbuerated. Please give me any suggestions.
If it's a daily driver I'd stick with EFI. Carb will need adjustments/tuning, and will get less mileage. Plus IMO, the TPI looks better
. Go with a slight cam, like the ZZ4, or the comp 302, some valve springs, roller rockers and some headers. An adjustable fuel pressure regulator and some good injectors.
. Go with a slight cam, like the ZZ4, or the comp 302, some valve springs, roller rockers and some headers. An adjustable fuel pressure regulator and some good injectors. Thread
