V6 to V8 wiring harness
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
2 injectors
the 305 might have a dual fan set up
length of wires
location of sensors
might be easier to use the correct harness
might be easier to splice your existing harness
never tried both yet, so i cant say for sure
also the 86 will be a MAF harness
your 91 will be a SD harness
length of wires
location of sensors
Transmission: 4L80E/4L80E
Find an uncut '86 TPI harness. It can't be that hard (look in the classifieds on this board, or post a wanted). You'll need the ECM as well.
Originally posted by DAN_92RS
hey you don't have a v6 with TPI its a v6 has MPFI. and its probably easier to buy a brand new wiring harness from painless performance
if your on a budget, it is possible
easier to buy a whole new harness, prolly
i looked into this from every angle, and it doesnt seem hard to modify
keep in mind, my harness is SD and i am keeping it SD
if you want a go from a SD harness to a MAF harness, then it will be more complicated......still doable though
