Need help with motor swap ASAP!!
Old Feb 24, 2003 | 06:27 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i'm in the middle of swapping my 305 with a 355 and i wanted to remove all my smog and ac stuff. but what am i suppose to do about the pulley and belt situation with no ac? are there belts that will just overpass it, or do i need some sort of pulley to replace the ac? thank you
Old Feb 24, 2003 | 08:48 PM
topher's Avatar
YOU WILL NEED A A/C DELETE PULLEY, OTHER THAN THAT U CAN BUY A SMALLER BELT TO COMPENSATE FOR NO AIR PUMP.
Old Feb 24, 2003 | 09:53 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I have a/c delet no smog w/slp underdrive crank pully and I used slp's belt for the crank pulley and just routed the belt different my.05
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
E Rod
Aug 28, 2015 05:17 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
