350 clearence
Old Feb 24, 2003 | 11:24 PM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Transmission: built 700r4
350 clearence
has anyone had problems with clearence putting in a 350 carb? I will be putting in an open crome airfilter. Just wondersing if anyone had problems with stock hoods.
I have a 86 z28
Old Feb 24, 2003 | 11:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes.
A flat-base open element will smack the hood. You need a dropped-base type.
Old Feb 26, 2003 | 12:08 AM
CamZ28's Avatar
Car: 86 Z28
Engine: 383
Originally posted by five7kid
Yes.
By flat base do you mean the one that just sits on top of the carb? Does dropped-base mean the one that goes over and around the carb like a stock one?
Old Feb 26, 2003 | 12:08 PM
five7kid's Avatar
Basically, that covers it.
The "standard" open element you'll see in the parts stores/speed shops will be flat base.
Old Mar 4, 2003 | 09:15 PM
AFatHippo's Avatar
Car: '88 Camaro
Engine: 355
i have a recessed base style air cleaner, and it had problems clearing the choke (electric), and the air cleaner not clearing the hood with a spacer on top of the carburetor. we cut the spacer down to the shortest possible length, and cut out some of the reenforcement on the hood. everything clears fine now
Old Mar 11, 2003 | 04:24 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
I put a carbed 350 in that has a vortec edelbrock rpm manifold which I believe sits a little higher than others. With a carbeurator on top there was zero clearance. The very top of the carb barely stuck above the hood line. A 2" cowl hood is on the way right now.
Old Mar 12, 2003 | 11:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look for an L69 dual snorkel air cleaner. They were made for the carb cars to fit under the hood AND have cold air induction parts. You can still get these are Year One.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
