Warming up an L69
Old Mar 2, 2003 | 04:58 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Warming up an L69
Hey guys,
I was hoping you may have some input here. This summer, I'm going to get back the shortblock of my L69 back, and I have almost all of the stock parts for it except heads on my 350 right now (intake, carb, exhaust, etc). I will be getting some 416 casting heads for the engine this summer if i can find a good set and have a set of short tube headers (1-5/8") in my room right now that will find their way onto this engine when it is done, as well as a new exhaust system.
Anyway, on to my question... Do you guys have any sorta 'low buck' ideas for pulling a few more hp out of my L69? Most of the major parts will be original, but will have headers and exhaust and no emitions stuff at all. I would like to try to get about 240hp out of it.
Thanks in advance.
Old Mar 2, 2003 | 05:25 PM
Pontiacman's Avatar
K & N Filter
Synthetic fluid in engine, transmission, diff.
Pulleys
Propper coolant mix, or even better NPG coolant
Old Mar 2, 2003 | 05:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Port the heads. Lots of HP for near free right there.
After that, cam selection is critical. You want all the lift you can get, with .050" duration around 210-214° on the intake and 10° more on the exhaust, and close to .500" lift. I'd recommend a Comp XE262H with 1.6 rockers, and NEW Comp 981 valve springs. Don't try to re-use a bunch of worn-out stock crap ones on a cam with aggressive ramps like that one.
The stock carb and intake are fine. Leave them alone.
My 83, with a pair of old double-hump heads (not the best for the application, but I had them laying around, so what the hey) and a Comp XR264HR with 1.6 rockers and Edlebrock TES, stock carb & intake & exhaust from the cat on back, all emissions devices installed and operating and having just passed California emissions inspection a few days before, put 214 HP and 282 ft-lbs to the rear wheels. That's around 260 HP at the crank. If I had 58cc heads instead of 64cc with equal flow, all else being the same, it should be good for 270 HP or a little more.
That should give you a good idea of what can be done without un-bolting and re-bolting all the stuff you can see but doesn't have much effect, but instead concentrating on stuff that actually makes more power.
Old Mar 2, 2003 | 06:38 PM
Air_Adam's Avatar
So you are saying that i should really just concentrate on the valvetrain? That was sorta what i was thinking too...
I'd love to port and/or polish the heads, but since i haven't done it before, i don't really trust myself to do it right. Is there really much power to be gained by doing a port/polish job?
Old Mar 2, 2003 | 06:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There is a lot to be gained. My first attempt was on the Worlds (did one cylinder of a stock head for practice). It was work, but came out better than I had expected (since it was my first attempt), and runs great. Since I did all of the other mods at the same time, it's hard to say how much the porting itself contributed (or how much the heads themselves contributed), but I couldn't be happier with the results.
Just hope I can say the same when the 396 heads are done...
Old Mar 2, 2003 | 11:03 PM
Air_Adam's Avatar
How hard would a job like this be to do to a set of 416's for a first timer like me? And if i do end up doing it right (fingers crossed) what kind of gain could i be looking at?
Old Mar 3, 2003 | 01:31 PM
five7kid's Avatar
First understand that you need to have a real die grinder with speed control - Dremel won't cut it. I have an air die grinder, it takes a lot of air compressing to keep up with it. Others use an electric with a seperate speed control.
I kept tabs of the time I spent on the Worlds. I had both heads end-to-end, did all of a particular operation on all 8 cylinders before going on to the next operation. It took me 10 hours. For reference, the one practice cylinder on the 416 head took me 2 hours. Part of the reduced time on the Worlds was the effeciency of not changing the tool all the time, but more so was that they were much easier to clean up.
Old Mar 3, 2003 | 03:54 PM
Air_Adam's Avatar
Well, the shop i'd be working at has an air grinder there, so i could use that. I was usig it just today actually... looks alot like a Dremel, but its much longer and alot more powerful.
So when I do this job, the goal is just to open the ports more right? I really wouldn't trust myself to do any kind of good reshaping of the ports.
Old Mar 3, 2003 | 04:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Buy the Standard Abrasives deluxe porting kit. It has some stuff you probably won't use, and not enough of some of the stuff you do use; but it's a good selection of different sanding and grinding things. And, it comes with a set of excellent instructions.
http://store.summitracing.com/partdetail.asp?part=9175
Old Mar 3, 2003 | 06:08 PM
five7kid's Avatar
You can download the instructions here http://www.sa-motorsports.com/diyguide.shtm
Excellent guidelines. The deluxe kit is what I used for my heads. Yes, I had to buy more rolls (probably because of the practice head). The pictures are of 305 heads to boot.
I've got another kit on the way for the 396 heads. Figured that would be easier than trying to buy the required stuff piece-meal.
Old Mar 3, 2003 | 10:44 PM
Air_Adam's Avatar
Well.. those links, especially the one to the port/polish guide were a good thing to see... I got the idea that this may be a pretty tricky thing to do and really easy to mess up from a book my dad had given me awhile ago that has alot of basic tuning and hi-performance tricks in it, the port/polish job being one of them. After reading that thing, it kinda scared me away from wanting to try this, but after reading a little bit of that guide, it really doesn't seem all that bad and I may yet try this. But it will have to wait untill September at the earliest because I will not have the engine back untill probably after June, I still have to find some decent heads for it, and will be doing 99% of the work at school, because they have a pretty good shop there, with probably most of the tools i'll need to do almost all of the engine work and it and i'll have almost all day to work on it.
So... any other little tips or tricks you guys could suggest aside from the porting and polishing job?
BTW, what should i use to strip all the old paint off the block, heads, pan and valve covers? If possible, i'd like to put the new paint on bare metal, instead of a layer of Chevy red on top of the factory black that is half gone already.
Old Mar 4, 2003 | 10:10 AM
five7kid's Avatar
Have them "tanked" at the machine shop. That caustic soda will strip 'em nice & clean.
Old Mar 4, 2003 | 03:43 PM
Air_Adam's Avatar
Hehe, can't beleive i didn't think if getting it tanked
Ok, got another question... should i use amn open element air cleaner on the engine, or should i stay with the dual-snorkel setup that came with my HO car? I have one of the CAI hoses and scoops for the driver's side, but not for the other.
Old Mar 4, 2003 | 05:09 PM
five7kid's Avatar
Keep the dual snorkel.
You're in luck, the passenger side scoop and duct are still available. The driver's side scoop is not.
Old Mar 4, 2003 | 05:43 PM
Air_Adam's Avatar
Were?
Old Mar 5, 2003 | 03:57 PM
Air_Adam's Avatar
Were can i get the scopp and hose?
Old Mar 5, 2003 | 04:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
GM dealer
Old Mar 5, 2003 | 08:21 PM
Air_Adam's Avatar
Ok thanks.
BTW, why do they only sell one scoop set? why not both?
Old Mar 5, 2003 | 08:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well it's been nearly 20 years since those cars were last made.... I guess they just ran out
Old Mar 5, 2003 | 11:37 PM
five7kid's Avatar
Year One (Next Generation) has them, as does Ram Air Box.
Old Mar 6, 2003 | 10:18 PM
Air_Adam's Avatar
Does Year One have scoops and ducts for both sides or just one?
Old Mar 6, 2003 | 11:49 PM
five7kid's Avatar
Passenger only.
At least, still had them about a year ago.
Old Mar 8, 2003 | 05:56 AM
Air_Adam's Avatar
Ok, i checked out YO... they have the passenger side scoop and IIRC they have the ducts for both sides.
I was also looking around at other stuff too... mainly cam kits.
What cam kit would you suggest for this motor? Assume mostly stock parts (carb, intake, lightly modded heads) but will have headers too. It has no emitions stuff either.
Old Mar 10, 2003 | 03:46 PM
Air_Adam's Avatar
Anyone?
Old Mar 10, 2003 | 04:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
XE262
I have a XR264HR in mine, not too bad if you have a roller setup around or feel like springing for it
Old Mar 12, 2003 | 09:25 PM
Air_Adam's Avatar
Cool, think i'll check that out... thats a Comp Cams set, right?
Old Mar 13, 2003 | 01:56 PM
Air_Adam's Avatar
Hmm... i've been looking around a bit, just because i was curious, and i checked out Comp Cams website. It looks to me like the 270H Magnum cam would be pretty good for this engine. It has a nice lumpy idle but good low/mid range torque. It was meant for a 4 barrel carb and headers (which i will have) and will not affect power accesories. "Great cam for cruising".
Sounds like a good set to me. What do you think?
Old Mar 13, 2003 | 02:25 PM
five7kid's Avatar
Are you keeping the CC carb and distributor? If so, the computer might not be too happy with the overlap of that cam. On the other hand, CC carbs aren't nearly as persnickity as SD TPI is.
If you are going non-CC carb & distributor, then the cam will be fine.
Old Mar 13, 2003 | 03:22 PM
Air_Adam's Avatar
Yea, i'd like to keep the CC carb and distributor. Why would the computer go nuts if i put in a cam like that?
PurelyPMD
May 5, 2016 04:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
amcnellis
Sep 16, 2015 04:16 PM
