NE1 bought a ZZ "partial engine"?
Old Mar 4, 2003 | 10:44 AM
84 Challenge's Avatar
I know there's quite a few on this board who have a ZZ4. But...has anyone bought the ZZ "partial engine" from say like...gmpartsdirect? If so...what heads, intake, cam did you or would you select? Just trying to get some ideas for my 83 Z later on this year. One more ?....will a quadrajet work on a ZZ4? Need to keep my emissions going.
Thanks,
Brandon
Old Mar 4, 2003 | 10:48 AM
Another question.....will my 305 heads work on this engine?
Old Mar 4, 2003 | 12:57 PM
JR305's Avatar
I just got my ZZ short block yesterday. I think they are a pretty good deal, forged crank, forged rods, and 4 bolt mains. If only they had forged pistons too.
I am going with pro topline 200cc iron heads, with comp cams XE 224/230, and the Holley stealth ram intake. Should make some power.
I would not use the stock 305 heads, a little too much compression for iron heads. The valves are also too small.
Old Mar 4, 2003 | 03:47 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I dunno... the 416 casting heads that came on most 305s and i think L98 350s were good heads because of the 58cc chambers, which will probably bring you anywere from 9.5 to 10.5:1 depending on your pistons. Put in some bigger valves too.
They are plentiful, so they are dirt cheap too.
GTAman
Jul 3, 2024 07:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
masonta
Sep 1, 2015 06:40 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
