Which Is Best
Old Mar 10, 2003 | 06:30 PM
RichSoucie's Avatar
Which Is Best
Which engine would you recomend for my upgrade from a 305 in my 86 camaro z28 i will problably take it to my local track now and then but it has to pass emmisions and be streetable and all that since this is my only car
Old Mar 10, 2003 | 09:07 PM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Go with a 383 Stroker.
Old Mar 10, 2003 | 09:12 PM
RichSoucie's Avatar
where can i get one of these that is turnkey i want somthing that i can just put in bolt up and start the car up and go.
Old Mar 10, 2003 | 09:19 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
nice turn-key engines can be found here.
www.enginefactory.com
Old Mar 10, 2003 | 10:08 PM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
lil friendly advice.. if your planning on dropping in a bigger motor and racing it some.... Get another car for a daily.
Whether it be a pickup, or a beater, preferably something with a big trunk
Old Mar 12, 2003 | 11:29 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
350... its much cheaper to build because you don't need the expensive 383 parts, and can make about the same power. A 383 will make more low end grunt, but with the money you'd save by keeping to a 350, you could put that somewere else like the exhaust or the heads and make just as much power.
A 350 will probably be better on gas too, but only marginally.
