if i am gunna do it i am gunna do it RIGHT!!
Old Mar 14, 2003 | 09:08 PM
icebird_1981's Avatar
i am sure u guys no whats up with me, i am swappin my lc1 to a lg4 that i have. well i have changed my mind since i got my new job, i have full access to a shop to do a motor swap, weld, bore, u name it i can do it (for free as long as it my own time), well ya anyway i figure if i am gunna do it i am gunna do it right. so here is the deal i have a lg4 with everything on it tranny and all. now i want to go 350 or a 383 if possible, what i was wondering is could i use everything on the lg4>tranny carb, ect on the new 350 or 383 block??? (is all i need to do it change the block??) please tell me what i have to do?? i want this by summer. so please any info would be great!!!
Old Mar 14, 2003 | 10:29 PM
transam84's Avatar
chevy small block parts are pretty interchangable for the most part. water pumps will fit on any small block, same with alternator power steering pump etc. of course if you go with a 350 or especally a 383 you will not want to use factory exhaust manifolds. the motors mounts on the blocks are interchangable. the one thing you could run into a problem is if you go from the "classic" intake and heads to a Vortec setup then your brackets such as alt may not work then you would have to go with something like a March bracket.
I went from a stock 305 in my Trans Am to a 383 and I put the 305 water pump, and motor mounts on the 383 w/out any problems but my intake was to tall for the 305 alt bracket so I did have to go with the March bracket for that and I had to make one bracket for my power steering pump but I think that was only b/c I went to a vortec head setup. I'm rambling here. in short unless you go with a Vortec setup everything pretty much is inchangable from any chevy small block V8.
Old Mar 16, 2003 | 11:04 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Pretty much. The 305 parts aren't necessary hi preformance but they will all physically bolt together.
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
bigals87z28
Jun 2, 2003 10:01 PM
buickboy
Feb 21, 2003 01:51 PM
bigals87z28
Feb 1, 2003 10:05 AM
icebird_1981
Theoretical and Street Racing
Jan 19, 2003 09:09 PM
