4.3 v6?
Old Mar 19, 2003 | 03:41 PM
Juicey's Avatar
4.3 v6?
some guy told me today that if i was doing an engine swap that i should put an S-10 4.3 v6 block in to my camaro today...he claims that block to be a 60 degree block but its a truck engine and from what i understand its a pain in the @$$ to make a truck engine fit. is there in truth in this guys opinion or should i stay with a 3.8 swap?
Old Mar 19, 2003 | 04:43 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
The 4.3 is a 90* block (same as the 3.8). It is just as hard to swap a 4.3 or a 3.8 into a V6 thirdgen as the transmission will need to be replaced in both instances.
The easiest swap is to change the 2.8 out for a 3.4 found in the 93-95 Camaros and Firebirds
Old Mar 19, 2003 | 06:19 PM
ede's Avatar
ede
even if you had a trans for a v8 a 4.3 would require differant motor mount locations and a few other modifications to make fit
CODY BEHNKE
Nov 6, 2001 09:19 PM
GreenMachine92rs
Aug 2, 2001 09:48 PM
gemmefire
Mar 16, 2001 06:32 PM
gemmefire
Mar 13, 2001 08:22 PM
PONTIMANIAC 90
Dec 20, 2000 07:56 AM
