2.8 to 4.3 questions
Old Mar 13, 2001 | 07:27 PM
gemmefire's Avatar
hello fello maro junkies, ive got a few questions about a 4.3 swap. what parts can i use on my on a 4.3 that are off of my 2.8 will i need to get a v8 trany..? and how much would it cost to instal a 4.3? and hook it up.? thanks
shawn
87 rs 2.8 stock (fast for a 6 but SLOW)
Old Mar 13, 2001 | 07:38 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
The 4.3 V6 is a 90 degree engine just like the small block. The 2.8 is a 60 degree block. I don't think you're going to have much luck with that idea.
Old Mar 13, 2001 | 08:22 PM
87RS402's Avatar
I see you found one good job!
I think the aircleaner and the oil pan plug will transfer over. Other than that nothing. Yes you'll need a 4 or V-8 trans. The 4.3 is a 90*, same as the SBC and BBC. The 2.8, 3.1, 3.4 are 60* engines. Different bolt patterns completely.
Remember that you'll need to set the 4.3 mounts 4-3/8" farther back than the V-8 mounts. You might be able to get the V-8 mounts for a S-10 sway and turn them around backwards. That way you can use the standard mounts.
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
redmaroz
Aug 16, 2015 11:40 PM
86Base
Aug 8, 2015 01:34 PM
