tip on LT1 conversion + p/s line
Old Mar 19, 2003 | 04:05 PM
bluepastu's Avatar
Car: 87 vert
TIP:
on the high pressure power steering pump. order the 95 impala(no modifications needed) just plugs right in, it's a perfect fit
Old Mar 19, 2003 | 04:06 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Re: tip on LT1 conversion + p/s line
Originally posted by bluepastu
TIP:
Thanks! I'll check this out.
Old Mar 20, 2003 | 07:59 AM
bluepastu's Avatar
Car: 87 vert
per the (moto18 email):
I'm in the process of installing the 95 impala lt1 into my 87. the pressure line form the pump to the p/s gear box was not part of the sell. so i tried first to us the 87 p/s line and add an extention hard line to the gear box(it failed). then i got a copy of the 95 impala p/s line and it worked super great no mods what so ever. and you can use your own 87sensor. I see that a lot for the 95 impala parts are adatable in the conversion process.
my p/s pump is at (if you were looking at the lt1 face on) in between 7 and 8 o'clock. the line goes from the left of the pump to the left of the a/c pump and down in between the a/c pump and frame then follows along side the cross frame and then goes up to the p/s gear box. PERFECT- JUST PERFECT.
if your getting radiator hoses you WILL need a 92 corvette lower hose and a 94 camaro upper hose(this hose has an external 1/2" hose mounted on it the would lead to the hard line that connects both outputs of the rear of the heads).
feel free to ask another question.
Old Mar 20, 2003 | 09:44 AM
mat89RS's Avatar
cool stuff, I shall order that since my homemade line is leaking.
thx
Old Apr 11, 2003 | 05:57 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I purchased the line you mentioned snd it will not fit my pump. I have a 94 LT1 and the line does not bend right for my pump. The impal uses a different pump, could this be why. Are you using an LT1 out of an Impala?
Old Apr 11, 2003 | 06:51 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The one that came with my Vette motor worked. All I had to do was put a slight bend in the hard part of the line where it comes out of the pump and it bolted hooked up nicely. The rubber part of the hose is a bit long for my tastes though.
Old Apr 13, 2003 | 02:59 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
We have the same problem on my friends install.
The line is like 3 feet long and only needs to go 6" since the Vette Accessories are on the drivers side.
Old Apr 13, 2003 | 08:40 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I'm eventually going to take the whole line into a hydraulic shop and have them make me a new using mine as a reference....just shorter.
Attached Thumbnails tip on LT1 conversion + p/s line-ps-line.jpg
Old Apr 13, 2003 | 12:01 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Looks better than mine.. i used the caprice one and well it loops back around on itself.. oh well doesn't interfere with anything..
midge54
Dec 27, 2019 04:14 PM
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 9, 2015 10:01 AM
zayne0
Aug 24, 2015 07:22 PM
