Speed Density LB9 to L98...
Old Mar 20, 2003 | 07:59 PM
demonspeed's Avatar
Car: 91 1LE
Engine: LB9
Transmission: MM5
Axle/Gears: GU6
I'm trying to decide what direction i'm taking with my next car, and i'm considering a 92 Z28 305/5speed G92. I feel it will be a lot easier to swap out the engine rather than getting the L98/700R4 and changing the tranny... so when dealing with the speed density setup....
What all is involved? This won't be as simple as dropping the motor in obivously. What about injector sizing, intake, etc... would I need a computer from the L98 car or can I reprogram the whole thing. Just please point me in the right direction to see if it will be worth it or if I should just move onto a 97 SS i'm considering... Thanks!
Old Mar 21, 2003 | 07:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It really is that simple.
Intake is the same.
Only thing that are different are the injectors, chip, and knock sensor. You don't need the whole computer.
Elephantismo
Feb 13, 2019 12:51 AM
85 Jimmy
Sep 30, 2015 07:56 AM
RGB2015
Sep 20, 2015 09:26 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
