Performance Question?
Old Mar 22, 2003 | 04:14 PM
firebird89355's Avatar
Car: 1989 pontiac firebird formula
Engine: Currently building a 355
WHAT KIND OF PERFORMANCE SHOULD I EXPECT FROM A 305 (L03) WITH 10:1 COMPRESSION 350 TPI CAM (FROM A L98), ALUMINUM DUAL PLANE INTAKE, 650 EDELBROCK CARB, HEI DISTRIBUTOR, AND FLOWMASTER EXHAUST? JUST CURIOUS IM ONLY BUILDING A 305 TO GET THIS BACK ON THE ROAD UNTIL I FIND A BIG BLOCK. ANY HELP OR KNOWLEDGE WOULD BE GREATLY APPRECIATED.
Old Mar 22, 2003 | 08:23 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
200hp, 275 tq.
Old Mar 22, 2003 | 08:25 PM
ede's Avatar
ede
PRESS THE LITTLE KEY ON THE LEFT OF THE KEY BOARD MARKED "CAPS LOCK" it'll help everyone here out what heads, thet would be one of the prime factors along with gearing.
Old Mar 22, 2003 | 08:55 PM
sorry about the caps!!! I will have stock 305 58cc heads that i pocket ported and they have been shaved about .020 and I have 2.73 gears right now until i get the big block in there. thanx again.
Old Mar 23, 2003 | 06:50 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Be luckly to get that, and that will be at the Flywheel and NOT the rear wheels.
Old Mar 28, 2003 | 06:54 PM
why so little?
the 350 tpi has 245hp/345tq i know its a smaller bore/same stroke but why would it be so low? hell most 6 cylinders produce more power than that these days. i honestly think it should be more than that. but hey its only to get it back on the road til i find a big block.
Old Mar 28, 2003 | 07:10 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The TBI motor has swirl port heads, with this giant ramp restriction thing in the intake part, the TPI doesn't; the TBI has a 2" manifold outlet, the TPI 2¼"; the TBI has a 2¼" Y-pipe, the TPI has 2¾"; the TBI motor came with 170 HP stock becasue of all its handicaps, and even with the handicap of TPI itself, a 305 TPI manages somewhere in the 200-215 range depending on details.
Horsepower == flow. Pure and simple. If it flows better, it makes more HP. The L03 is one of the poorest flowing motors (along with the LG4) that GM has ever made.
I'd agree, if you still have TBI heads and exhaust, you could put an 1100 Dominator and a Super Victor on that motor, and you'd still only get 200 HP worth of flow through it, tops.
Most modern 6-cylinders have alot less restrictions in the heads, so they FLOW better than the L03 did. That's where HP comes from. HP equals work done per unit time; that equals gasoline molecules burned per unit time; which requires air molecules per unit time; air molecules (in cubic feet) per unit time (minute) can be measured in Cubic Feet Per Minute. Flow.
Old Mar 30, 2003 | 09:43 AM
are these the heads?
14102187...87-91...305..........1.84"/1.5" valves
those are the heads i have are those the ones that are swirled port ? im just trying to make sure we are on the same page. thanx , thomas
p.s. also im using a aluminum dual plane intake not the tbi anymore,with headers if these will fit my car. :hail: :hail:
Old Mar 30, 2003 | 10:47 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes. Those are the garbage.
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
