ok ok ok! i know 2.8 to 5.7 tpi
Old Mar 30, 2003 | 10:12 PM
firebird13's Avatar
Ok guys...I just want to know exactly how hard would this be for a beginner? I have never swapped engines before..Im planing on getting a donor car..so i will have everything..but how hard would it be for me thats never swapped out engine..I know alot about it but never done it...if that makes since..Just tell me the skill it will take and if this could be done in a weekend or week project?? plz give me info!
Old Mar 31, 2003 | 12:01 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Swap
I just finished one. I had an '87 Firebird and an '87 donor car.
The hardest part is removing the V-6 motor mounts and installing the V-8 ones. They mount in different holes but the holes are there. The brake lines are on the rear of the crossmember (in the way of the ex. crossover) so they need to be moved to the front like a V-8. Other than that it's just nuts and bolts. I unhooked the harness from the donor car and left it on the engine, plugged it in on the V-6 car (checked all the connectors to see that they matched) and it fired right up.
Good Luck.
Don>>>
diana227vegas
Jul 8, 2016 12:27 AM
stalkier
Dec 6, 2015 11:25 PM
777Shock777
Oct 29, 2015 04:30 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
