Old 350 Block differences
Old Mar 31, 2003 | 03:16 PM
4x4Elcamino's Avatar
I have a few old pre TBI 350 blocks laying around I would like to build up to replace my 305 TBI. What are the differences in the old early 70's blocks and the one I want to replace. The knock sensor comes to mind. What else?
Old Mar 31, 2003 | 05:49 PM
StealthElephant's Avatar
Car: 87' Iroc
all 70-86 350's use the same oil pan right?
Old Mar 31, 2003 | 06:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No. Rear main seal changed to one-piece in '86. Also different end seal widths out there.
Dip stick changed sides in '79.
The knock sensor didn't affect block design. They just screwed it into the coolant drain hole that's been there since 1955.
Old Apr 1, 2003 | 08:30 AM
So there is no reason I can't use an early modle block and heads?
Old Apr 1, 2003 | 02:36 PM
five7kid's Avatar
You just said "blocks" originally.
Heads are a different story. Pre-'68 don't have accessory mounting holes on the ends of the heads. Most '70's heads are pure smog junk. Whether you "can" use them or "should" use them is a different question, though.
Old Apr 1, 2003 | 07:24 PM
Aron213's Avatar
Car: 88 Iroc
Im using HITHERE 1969 block in my 88 Iroc now, besides the obvious like the pan and dipstick, HITHERE did have to find HITHERE place to hook the oil pressure sensor that was near the oil filter. Not sure if TBI's use that or not.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
