Help picking out a Cam
Guest
Posts: n/a
ok i just got done doing the motor swap. btu the cam we put in has to much of an overloop and it won't pass the damn sniffer test. so what is the biggest cam i can get. i have edelbrock performer intake, Hooker headers (2055) and the compression has been uped to 9.5:1 this cam will be going into a Chevy 305 with a .030 over bore. i want a cam that will give mid to upper HP. and a choppy idle. but again it HAS to past the sniffer test... any idea's??
P.S. the motor is not computer controled and it is running a Holley 600cfm carb.
Thanks for the help!
Transmission: 4L80E/4L80E
Re: Help picking out a Cam
Originally posted by My86Firebird
i want a cam that will give ... a choppy idle. but again it HAS to past the sniffer test... any idea's??
Car: 4
Engine: 6
Transmission: 5
What test does it have to pass?
Is the rest of the emissions eqpt on the car? Specifically, AIR and the cat? It might be a whole lot easier to go that route than to dig into the motor.
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
What are your cam specs? How bad did it fail? Unfortunately, you will have to ditch the choppy idle to pass emissions.
Becuse you have a carb you will have a few more problems. You may have to re-jet for emissions compliance.
Guest
Posts: n/a
i don't know the specs on the cam that is in it right now... or was in it (i'm ripping apart the block now) i'm just going to use this other cam i have laying around. i got bored and wanted to do somehting do i started ripping a part the block... ( i know i know how to put it back together ) Thanks anyways
junkcltr
Aug 2, 2019 11:12 PM
Street Lethal
Apr 30, 2019 12:14 PM
