Fast Burn 385 crate engine in a 1992
Old Apr 14, 2003 | 08:30 AM
kaupca's Avatar
Car: 92 Camaro RS
Is it possible to swap a Fast Burn 385 crate engine in a 1992 camaro? Could I retain all the stock accessories? The car is currently a 305 tbi could I use the intake and throttle body off of it? Would I need to change the wiring harness or computer? Thanks
Old Apr 14, 2003 | 01:16 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can bolt it in. The 305 TBI & intake will choke it. The computer probably won't be happy with you, but that's PROM tuning.
Hope you had exhaust upgrades in mind.
Old Apr 18, 2003 | 10:07 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, he is right...it will bolt up just fine...but you have to change everythin else for it to work correctly without starving the thing for air an fuel.
-brian
Old Apr 19, 2003 | 09:30 PM
kevinc's Avatar
Car: 1982 Z28
The FastBurn heads that engine comes with are Vortec design...while they can be drilled & tapped for conventional intakes, the ports are higher which creates sealing problems.
You can buy TBI intake manifolds designed to accomodate this from SDPC2000.com among others.
Take a look at this for a good idea of the sealing issues:
http://members.fbody.com/kevinc/vortec/vortec1.jpg
I love all these "yup it'll bolt right up fer sure yup" posts from yahoos who have never done it...
Vintageracer
Jan 10, 2020 05:33 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
