I need your opinion inside please...
Old Apr 21, 2003 | 04:05 PM
87Formula4bbl's Avatar
Car: '87 Formula
Sorry to do this guys, but I need some information so I can make a decent decision about what to do here. I'm kind of stuck.
Can anyone give me a ballpark estimate of what kind of power I'm looking at with this (everything is fresh and redone):
3970010 350 block
Flat-top pistons or slightly domed
Ported and polished 081 heads (58cc)
Stock dual plane aluminum intake
Rochester 4bbl cc q-jet
Hedman 1 5/8" headers
Full 3" exhaust minus cat conv. plus flowmasters
Moderate hydraulic cam (havent decided yet)
Like I said I just need a ballpark estimate. The reason being, is well, my 305 is done for for now. Pulled it out, needs bearings. I dont even have money for the 305 to get rebuilt as it is, but the way I see it is that (having been given a free 350 engine), I may as well get the 350 block machined and rebuilt, and throw my 305 heads and everything else on untill I have the money down the road to get some better heads, intake, etc. The 305 was a roller block, I just bought a new Comp 270HR for it (damn those things are a lot), I had everything together and noticed something was knocking, so the cam has about maybe an hour or so on it. I can't reuse it in the 350 so I will be taking a loss there, cause I'll have to go hydraulic cam in that. I just want to know what kind of gains I am looking at over what I had before, for what I am spending and what I am getting. I need to do this economically, but I want it done right (bottom end) so I dont have to mess with it down the road. I figure I may be saving money in the long run by going the 350. I really only have about $800 tops to spend, I figure I should be able to get all the maching done with that, I think I have someone to help supervise on assembly on my own. Please give me your opinion.
Later,
Ben
Old Apr 21, 2003 | 07:12 PM
kevinc's Avatar
Car: 1982 Z28
Re: I need your opinion inside please...
Later,
Ben
If you're the one doing the assembly, I'd say you'll be lucky to make over 190hp. That is, if it doesn't throw a rod the first time you crank it.
Old Apr 21, 2003 | 07:15 PM
Car: '87 Formula
Well I just talked to my mechanic tonight, he is helping me build it, so it is under his supervision.
I want to take advantage of an opportunity to learn while at the same time, doing it right. So it WILL be done right.
Old Apr 22, 2003 | 07:35 AM
Car: '87 Formula
ttt
anyone?
Old Apr 22, 2003 | 12:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't understand your reply at all, Kevin (unless you know each other and know something we don't ).
I certainly wouldn't use domed pistons. Flat-tops are going to put you in the 10+:1 CR territory as it is, unless you unshroud the valves a little (increases chamber volume) and use a thick composite head gasket.
With a 270-like cam, a good exhaust and good air cleaner, you should easily be in the 275 flywheel HP range, probably close to that rear wheel HP.
Old Apr 22, 2003 | 12:53 PM
Car: '87 Formula
Maybe he had a bad experience himself while trying to do something similar, I dont know, but that wasnt really the answer I was looking for (Kevin).
Excellent, thats what I was looking for, five7kid *sorry*. Short honest answer. I'm going to go ahead and do the 350 block, that way I have "room to grow" down the road when I can get some better heads.
Old Apr 22, 2003 | 01:28 PM
kevinc's Avatar
Car: 1982 Z28
Asking for HP estimates without cam specs reveals a frightening lack of knowledge...so instead of estimating HP, I estimated your mechanical ability and formulated my reply. You said "please give me your opinion" so there ya go.
Don't want to invest time doing a little research, you'll end up with a real crapper of an engine...just do a search on username SlowMaro for a recent example.
Old Apr 22, 2003 | 03:40 PM
Car: '87 Formula
Sorry for being vague. Like stated above, I DID HAVE a 270H Comp cam for the 305. One thing I had to decide was whether to use an older hydraulic (non roller) block which was given to me, in which case I'd have to get a different cam (set), but more than likely would be very similar spec-wise with the 270h, but probably larger (in terms of performance-wise, yes I realize that roller and regular hydraulic cams have different profiles), so I thought I'd use the 270 for a lower-bound (or base, if you will) standard to estimate what I'd be seeing out of the motor. On the other hand, if I decide to wait until I can come up with a roller block (350), which I think I will do now since I already have the money invested in this cam, and have the lifters and all, then I will be using the cam I've already purchased (yes, the 270H).
I dont want to be rude and start an argument over something so stupid, but I dont see how you can judge my mechanical ability over some bit of information which I may have left out or led you (unknowingly and honestly) by. Sorry for that. Just because this is my first time building an engine also does not mean that I'm a complete dolt when it comes to mechanical ability. Even if I had little ability, you still gotta learn somewhere dont you? I seriously doubt that you were just born with instincts and built-in knowledge on building high performance engines, but I could be wrong. Anyways, I stated above that I have good supervision. As a matter of fact, he's the BEST guy I know at it. I know, you'll probly say "well that aint sayin much, just from lookin at what kind of ability you have"...well, trust me, he knows his chit.
Oh and by the way, I've got a LOT of time invested researching this, so much so that my school grades are severely suffering, if that is saying anything. As a matter of fact, I've read through quite a few of/or consisting of SlowMaro's posts. So dont lecture me on research please. I'm not just blindly purchasing cams/parts and throwing them together and thinking I've got some good ****. Like I said though, I AM trying to do the best with what money I have for the time being.
I think I asked a completely legitimate question, compared to some others on here I've been seeing as of late. I shouldnt have to write an essay to explain myself, but I didnt want to give you the wrong impression. Once again, sorry for the confusion, and now I must go to work before I'm late. No hard feelings.
Later,
-Ben
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
KO1
16
Oct 15, 2015 05:00 PM
