motor hesitating at low rpms
Old Apr 21, 2003 | 07:11 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
i finished my swap and had my carb adjusted, motor timed and fuel all set. Im still breaking it in so i dont step on it too hard but i have gotten on it a couple times and after i do when i come to a stop then accelerate normally, the engine hesitates at about 1500 rpm and drops to about 500 like its gonna stall then picks back up to about 2000. Could this mean i am running too rich or too lean? What do i do to stop this from happening. I have a carter competition 750 carb.
Old Apr 26, 2003 | 08:30 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Sounds like too rich, or maybe a vacuum leak.
Old Apr 26, 2003 | 10:14 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Sounds like the accelerator pump is not functioning or does not have the proper spring rate. The jets could be worng as well.
To get a carb setup right you should dyno tune.
theshackle
Sep 17, 2020 08:26 AM
jklein337
Sep 19, 2018 06:23 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
