Block swap
Old Apr 23, 2003 | 12:49 PM
91zconvt's Avatar
Car: 87 Iroc
Block swap
I'm really new to this, and don't know much, so I need some help. My friend just bought another engine for his camaro, and he said I could have his engine block and headers for free. It's a 350 block. My question is, could I just have someone swap the blocks, or is there more to it than that? I have a 305 TPI right now, and I just want to know what I'd have to do/get to make everything match up.
Oh, on another note, my car has a T-5..>Should I be looking for a new tranny?
Old Apr 23, 2003 | 01:24 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Is it just the block, or the whole motor?
Old Apr 23, 2003 | 01:38 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
you need new head gaskets..lol
daz
Old Apr 23, 2003 | 03:42 PM
91zconvt's Avatar
Car: 87 Iroc
Just the block, and he said he'd give me his headers too
Old Apr 24, 2003 | 01:33 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You'd need the parts to complete the block. Heads, internals, cam and so fourth. Your 305 parts aren't generally going to be interchangeable. What is interchangable won't be worth the minior performance gain you would get just from a "block swap". If I were in your place I would keep the 350 block and build it up. Forged internals and a stroker kit. So when it's time to do the engine swap I would be doing it for something really worth while.
You might want to think about getting a new Transmission as well. It is my understanding that the T-5 can't really handle all that much torque. Also they aren't that reliable as I understand it. Anyone want to step in and give thier opinions, be my guest I am not an authority on the subject.
I am however a firm believer in doing it right the first time. Hope this helps.
Old Apr 26, 2003 | 08:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Well, his rotating assembly (rods, crank, etc) should drop right in, but he will need new pistons for sure.
All the bolt on's like intake, exhaust, heads, etc should all change over too.
Old Apr 26, 2003 | 08:44 PM
bes217's Avatar
You need a whole new rotating assembly. I would get new heads and a cam too. Your tranny should be OK for a while but not too long. Sooner or later(probably sooner that later) you are going to have to get a new tranny.
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
