Crate engine ???'s
Old Apr 23, 2003 | 07:56 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Crate engine ???'s
What crate engines can I use and keep all my emissions equipment functional?
This is particularly important in my state. I know that if I got an L98 and swapped it for my LB9, that would work. My preference though is to get a crate engine that already has the power I want rather than building up a L98 for a swap.
Any advice is as always appreciated.
Old Apr 23, 2003 | 11:08 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I bought the 300 hp 350 crate motor from Autocenter.http://www.goautocenter.com/300hp_tpi_1987-89.htm
It passes smog in CA as a 305, and regularly makes 4.6L Cobras look bad. Over 25k on it since putting it in without any problems.
You'll need a custom chip.
-Rich-
Old Apr 23, 2003 | 11:09 PM
ilikerocks's Avatar
check this site out..has a 326 hp 350...emissions legal http://www.desertperformance.com/engines.htm
Old Apr 24, 2003 | 09:18 AM
87WS6's Avatar
I appreciate the response. I just got done looking at the prices at Desert Performance. Man those are not bad. Definatley in my price range. Thanks alot.
Old Apr 24, 2003 | 10:55 AM
TexasLT1's Avatar
Car: '92 RS
87WS6, what part of texas are you in? As far as I know only the large cities do testing, and they just started in the area surrounding Houston, of which I am unfortunately a part of. I'll worry about the emissions later though, I've got another year before I need to get it inspected.
Old Apr 24, 2003 | 01:28 PM
87WS6's Avatar
I'm in Dallas. I don't know anyone in the outlying areas that I can use to "garage" my car to avoid such issues. I was thinking that if the opportunity ever arose where I could get another third gen that was exempt from emissions say a pre 1986 LG4, I would gut it and transfer all my stuff over to it and do the swap in that car. I find though that I like the 1985-1992 F-Bodies to much for that.
So I can just go the emissions compliant route.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
