is this correct from what ive read in my searches?
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
basically all that i need to to to swap my 1987 2.8L engine in my firebird for a bran-new 350 is to take all the parts off my 1989 Trans am doner car, swap everything on to my firebird from the trans am (computer and all??), then put the 350 in?
if this is true then all i would have to buy is an exhaust and a transmission (the trans am has holes in the exhaust and the transmission is auto and i want manual)
if im wrong please let me know
thanks
tom
thanks
tom
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Do not forget the springs. Also you will probably have different axl ratios between the two cars. You will need to swap the gears for the VSS as well.
Since you have the donor car take all the neccessary suspension parts. Springs, Sway bar, Rear Axle gear (posi if equipped) If it has rear discs, Do a complete axe swap. Make sure you change the mastercylinder and proportioning valve. After putting on all the performance parts you're car will perform better all around.
Ghettobird52
Jul 5, 2024 11:18 PM
mdtoren
Aug 16, 2015 05:45 PM
