LT1 crank hub
Old May 1, 2003 | 06:47 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
LT1 crank hub
i have to get the hub that the harmanoic balancer hooks to off..
i tried for a good hour to get it off...i was using a harmonic balancer puller..and it didnt work for ****..
i have to get the hub off in order to get the rest of the motor apart..
i would just lift the crank out with it on but the timing chain is still on it so i cant do that..
Old May 2, 2003 | 01:37 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Well, you will need to remove the little spacer off of the bolt that holds the hub onto the crank and then screw the bolt into the crank a little bit and then put the puller on.
Then it should come right off.
We did what you are doing and you are basically pushing on the inside of the hub while pulling on the outside. You will see that there is a small hole in the hub that the puller won't go through and that is what the bolt is used for.
Old May 2, 2003 | 09:29 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I'm not sure what a harmonic balancer puller looks like, but you need a jaw type puller. Also, take some PB Blaster or WD40 and spray from behind the balancer to where it seats onto the crank. Mine was difficult to get off as well, but eventually popped.
Old May 2, 2003 | 01:07 PM
David Petersen's Avatar
I just pulled mine off my LT-1 I used a wheel/hub puller. As stated before take the bolt out, remove the washer/spacer and go back in a few turns and you should be go to go.
Old May 2, 2003 | 03:51 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
lemme make sure im on the same page with u guys..theres a hole in the center of the hub..theres a bolt in there..i have to get the bolt out to pry off the hub
theres a problem with that,,
if i try to loosen the bolt the crank turns because i have all the pistons out
i didnt know this was gonna be a problem untill i tried to take the bolt out..and the thing is tightened to 456 ft lbs
this suck @ss...i got my rings and bearings ready to rock but i cant get the fricken crank out to put in new main bearings
should i put the rings in the pistons and bearing on the rods and put the pistons back in then get the bolt off and then replace the main bearings?
ahhhh crap then id have to take the pistons back out to put the crank back in
FU#K the little things!!
Old May 2, 2003 | 05:01 PM
Zepher's Avatar
Ah, if you had an impact, it would make it a lot easier to get that bolt out right now. didn't realize the motor was all apart like that.
Old May 3, 2003 | 02:23 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
any ideas? lol
ill try an impact...
id really hate to have to put the pistons back in just to get a friggin hub off, then take the pistons back out...then put a set of rings on the pistons and put them back in..
that would be a serious PITA..let alone a 4 hour set back
Old May 3, 2003 | 02:37 AM
Zepher's Avatar
You could put two bolts into the hub and use an bar between them for leverage and then a socket on the centerbolt.
Old May 3, 2003 | 09:33 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Just went through this all myself...yes, use an impact, then use zephers method to get the hub off.
Old May 5, 2003 | 09:44 AM
I put the three balancer bolts back in part way and slide a large screwdriver between two fo them to hold it steady.
Old May 5, 2003 | 10:50 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
alright guys ill give that a shot tomorrow
Old May 6, 2003 | 10:49 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
well i got the bolt out today..
i put a breaker bar betweent he bolts and the socket pulling the other way...it worked like a charm, although i bent 2 bolts lol
then my dumb@ss forgot the hub puller
Old May 9, 2003 | 05:38 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
update
it seems in all my futile efforts to remove the hub with out takin out the bolt i have stripped one of the holes on the hub...
now im converting to carb so i cant use the orignial damper because the timing tab on the timing cover wont clear it..the purpose of the hub adapter is to move the balancer out to clear the optispark..im not using an opti so i dont need the hub..without the hub i need a smaller (6 3/4) balancer to fit under the tab on the cover...
so i dont need the hub...anyideas on how to get it off...other then wack the **** out of it..
i was thinking about threading the bolts through the puller and intot he hub...the tacking welding a few spots so the bolts wont back through the threads...
sound good?...any other ideas?
Old May 9, 2003 | 05:55 PM
Zepher's Avatar
Use a 3 claw style puller, the kind you use to take gears off with.
Old May 9, 2003 | 05:56 PM
Zepher's Avatar
Also, in the manual, it shows 3 long bolts that are smaller than the holes in the hub and nuts at the end of the bolts.
Old May 9, 2003 | 06:04 PM
Engine: 406
I busted 2 harmonic balancer removers trying to get mine off..The universal puller worked good for me..3 claw...
Old May 9, 2003 | 09:56 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i didnt even think about putting nuts on the bolts
Old May 11, 2003 | 12:49 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
i got it off today...i tell you what, gm really pressed this on
i had some slack between the bolt and the hub so i know i wasnt working against myself, but this was incredibly hard to get off..
i put nuts on the bolts and the holes in the balancer were only slightly bigger then the nuts..they were started to come through the hub!!..
after i got my dad, we both went after it..we crank that ratchet so hard i thought we were gonna break it...then all the sudden it went..."crack" and broke the seal...then it was very easy to get off..
ohh that washer thats "pressed " on to that hub bolt..mine wasnt pressed on..it was like any other washer, just floppin around...
do i need that bolt?
thanks guys!
Old May 11, 2003 | 01:04 AM
Zepher's Avatar
thanks guys!
Depends, it might be too long or too short.
Put the new damper/balancer on and see if it works for you. Otherwise just got a standard sbc crank bolt.
Old May 11, 2003 | 01:30 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
thanks..ill let you know what i find out
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
WejaZ28
Oct 3, 2015 07:38 PM
