Asking for help...3.4L to LS1
Old May 7, 2003 | 09:51 PM
sccerstyle's Avatar
I currently have a 3.4L 1995 camaro stock 5 speed manuel....i want to put either an LS1 or LS6. I can't decide which one plus I don't know if they will fit. I have called a bunch of chevy owned dealerships/part stores and they know nothing. I need to know what all would have to be modified in order to get them to fit. I understand that from what I have heard the LS1/6 both have a 6 bolt pattern and my car has a 9 bolt. Is that true and will they still fit? What about the fuel pump? Exhaust? Computer? and what is a reasonable price. Best I have found so far is from Pace Parts at http://www.paceparts.com/subcatmfgpr...9&1=241&2=1084 Anything better out there? Thanks for the help
Old May 7, 2003 | 10:25 PM
bes217's Avatar
Well, first of all I shouldn't even bother to reply to this topic. There is a sticky at the very top of the page that should answer all of you questions. If you need anything specific other than that then ask those specific questions. But, please use the search button before everything else.
Old May 7, 2003 | 10:26 PM
Keith5's Avatar
Car: C1500
Yes of course it will fit. 98-02 cars came with the ls1 stock, and your car is just one of those with a 3.4 v6. You will need to change the computer, transmission wiring harness, and about everything else under the hood. I donar car would probably be your best bet.
Old May 8, 2003 | 08:10 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You also need to change the springs, motor mount placement (I think). Try here.
http://www.ls1tech.com/
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
