Long or short water pump??? I have no idea which to buy.
Old May 14, 2003 | 01:44 AM
Team P.S.I.'s Avatar
Car: 88 Z28
Engine: 408 Small Block
Transmission: TH350
Axle/Gears: 9" w/ 3.90's
Will either water pump work as long as I have the right brackets for it?
Im planning on using a flex fan setup so i dunno which one I need to get a good fit.
Any help?
Old May 14, 2003 | 07:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What sort of bracket setup and car are you planning on using this with?
Why are you setting the car up to run hot by using one of those ineffective fans?
Old May 14, 2003 | 09:59 AM
Car: 88 Z28
Transmission: TH350
ITs a late 70's block with early style heads.
I wont be using the serpentine setup.
Old May 14, 2003 | 10:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The block makes no difference. They're all the same as far as that goes.
When you say "early style heads", do you mean heads with no bolt holes in the ends (68 back)? What bracket arrangement are you going to use?
Old May 14, 2003 | 09:42 PM
Car: 88 Z28
Transmission: TH350
The heads have accesory holes.
Im not sure what brackets I will use...Ill have to find some to match the water pump I guess. :-/
I was just wondering if it was so damn long that I couldnt use a flex fan setup.
Old May 15, 2003 | 06:11 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The "long" pump is the stock one for nearly all cars since about 69. It goes with all the bracket arrangements used since then.
The "short" pump goes on earlier cars with heads that didn't have the holes; and on Corvettes up to some later year, because of clearance issues. People use it on race cars just to save space and weight.
Without knowing more about your car it's impossible to say for sure; but it sounds like you probably have a normal car of some sort, probably 69 or later, so the "long" pump would be what you need.
If this is a thirdgen, you can get the brackets off of something like a early-mid 80s Caprice which are real plentiful in the boneyards, just get all of them off of one car as an intact set.
Old May 15, 2003 | 09:59 AM
Car: 88 Z28
Transmission: TH350
thanks
Old May 15, 2003 | 06:56 PM
Pontiacman's Avatar
Don't forget all the pulley sizes. You don't want a short water pump with the pulleys for the long pump cause the belt won't line up.
Old May 15, 2003 | 08:03 PM
Car: 88 Z28
Transmission: TH350
Exactly....I didnt know which brackets I was going to need.
Old May 15, 2003 | 11:10 PM
Justin 87 GTA.'s Avatar
long probably. short to the best of my memory has only a pennies width between itself and the block. 2 fingers on the long. i believe. make sure the rotation is right
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
