Compression ratio calculation
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
You can calculate it here:
Compression Ratio Calc
You'll need to know the piston deck clearance spec.
The valve relief volume is about 5cc's on a flat top piston.
Some replacement flat top pistons are .025" from the top
other common ones are .045" (on a standard block) This will affect the final compression ratio. If the block has been "decked" this will affect it to.
You can select different thickness head gaskets to adjust the compression too. .015" .028" .039" .051" are available.
Damon
Sep 26, 2015 04:29 PM
