V6 vs V8 emissions
Old May 15, 2003 | 10:50 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
V6 vs V8 emissions
Which is going to produce more emissions:
'84 2.8L V6 2bbl, non CC, EGR & AIR... poorly tuned (passed DEQ)
OR
Same vehicle with '87 305 LT1 Cam, Cat, NO EGR/AIR, Headers, edelbrock 600CFM Carb.
Think I can pass the sniffer with the V8 and no egr/air?
Old May 16, 2003 | 06:02 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
to put it bluntly, NO.
you need your EGR/AIR in order to pass.
Old May 16, 2003 | 11:05 AM
The reason I was asking, was that I've heard the 2.8 puts out worse emissions than a V8.
Old May 16, 2003 | 02:36 PM
Hmmm... tough one. Standard logic tells me that V8 = more engine = more power = more emissions, but GM engineered the emission controls to burn just as clean as any other engine, so with all the smog controls hooked up, I would say they are the same.
Old May 16, 2003 | 05:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Since you say the V6 is poorly tuned, the V8 would probably do better.
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
