400 sbc question
Old May 18, 2003 | 06:48 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
400 sbc question
Hi
I am swapping a 73 model 400 sbc into a 92RS. The cylinder heads do not have the neccessary accessory holes to hook up the factory a/c. Any suggestions other then buying /swapping out new heads?
Thanks!
Old May 18, 2003 | 06:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Buy/swap out the heads. There are no alternatives. If there were, somebody would have figured it out sometime in the last 35 years since the heads with bolt holes came out, and those old heads wouldn't be quite as worthless now as they really are.
Those aren't the heads off of a 73 anything, least of all off of a 400. They're off a 60s motor of some sort.
ede's Avatar
ede
either the heads have been swaped or you don't have a 400, all 400s shoukld, or would, have the holes for accessories. you need new heads that have the holes.
Old May 18, 2003 | 07:13 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
the motor is a 400. it has been rebuilt by us already once. We had it in a 73 camaro without air but need heads that will adapt to a/c. The motor is a 73 model in which the air was on the drivers side. The a/c is on the passenger side in the 92; therefore, we dont have the capability to mount it. There is only the one hole that used to house the alternator (1973). Is there an aftermerket bracket that can be used on the heads for the conversion or would a GM head (ex. 350) that could have the steam holes drilled, etc. work with the 400 ? Thanks!
Old May 18, 2003 | 07:14 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
the casting numbers off of the heads match up to a 400. We pulled the motor out of an original 73 caprice. Thanks!
Old May 19, 2003 | 03:11 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Did the RS have a 350? You might be able to swap in the stock RS heads provided they are 350 heads and they are 76cc combustion chambers. If you are that lucky, then all you have to do is have your steam holes drilled in the RS heads. Most machine shops can do this for about $50. If the RS had a 305, your out of luck. 305's had a 58cc chamber which is way too small for a 400 with stock pistons. REGARDLESS OF WHAT HEADS YOU USE, MAKE SURE YOU HAVE STEAM HOLES!!!
Old May 19, 2003 | 09:22 PM
geoman's Avatar
Car: 74 Camaro
Engine: 358
Transmission: TH350
thanks wes...
Actually its my friends car and it came with the 305... What you said about the 350 heads would be the best thing. I told him that but he wasnt sure so thats why I posted for him. I bnelieve its the best way and I have a set of 350 heads that can be modified for his 400 and added. Thanks again!!!!!
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
