tpi wire harness removal
Old May 22, 2003 | 07:12 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
Transmission: 350 turbo
i posted on the tpi board,but no one responded.i have or had a 350tpi iroc.now i have a 427 dual quad monster.it is a 1987.i sold the other stuff to a fellow user.my question is,the harness seems to have taken everything with it,would it be easier to re-wire it all,or just get an old tpi harness and butcher it?will another harness work,like a tbi harness or something without so many wires?thanx and sorry so long
Old May 22, 2003 | 11:16 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
In my personal opinion, I would say wire everything yourself from square one, because if you go buy a TPI harness, they aren't exactly cheap. Do it yourself to save $$. What all are you wiring?
Old May 24, 2003 | 03:56 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
WIRING
i have to wire the alt,guages,tach,wiper motor,etc...i thought maybe i could get an old harness from the boneyard,but i still don't want all that crap everywhere.would a tbi harness work?thanx
Old May 24, 2003 | 08:32 PM
If that's the case then I would just go to a junkyard and get a complete harness for your application, then just delete the things you don't need or use.
Old May 24, 2003 | 08:42 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
seems to be best
that seems to be the best option.would a tbi harness plug up to the boot that is on the drivers side below the master cylinder,you know where the tpi has two plug-ins?i thought i had read that they were very similiar.thanx for responding
Old May 24, 2003 | 09:08 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
get a tpi harness and use a small small screw driver to pull the pins off the wires you dont need. but also. if you pull a tpi harness apart, the wires that connect at the drivers side firewall. dont really connect to anything on the ecm harness. on my 87 350tpi the wires on that boot were 2 brown wires comin from the alternator, wire for the oil gauge wire for the temp sensor, large pink wire to the ignition coil. white wire to the ignition coil i assume for the tach. 2 thick red wires to the starter and maybe a couple more. but basically everything you need to make the car run and have gauges etc
Old May 24, 2003 | 10:13 PM
MOCCASIN's Avatar
Car: 1987 iroc
Engine: 434 bbc
wires again
thanx for the response again.i think that i will try to find a cheap one to modify so that i can just plug it in.should save a lot of hassle.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 8, 2015 07:09 PM
