L05 Question search didn't find
Old May 24, 2003 | 03:21 PM
dennis6's Avatar
Car: 1991 Camaro RS
Does the Caprice L05 #12513151, use dished pistons or flat top pistons?
Old May 25, 2003 | 12:20 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I'm gonna stick my neck out on this one..
I have an LO5 (it's all torn apart now ) that came out of a '90 K2500 (not a Caprice) that has/had dished pistons.
Since it's the same engine code, I'm guessing it has the same hardware as the Caprice (short block), but maybe had different cam and heads.
Even with a shot in the dark, it's a 95% chance they're dished.
Old May 25, 2003 | 01:08 PM
dennis6's Avatar
Car: 1991 Camaro RS
Thanks. Guess the L05 is a waste of money then.
Old May 25, 2003 | 03:57 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
What are dished, and what flat top pistons?
I am assuming dished dont offer as much in the way of power and flat top?
Old May 25, 2003 | 04:29 PM
dennis6's Avatar
Car: 1991 Camaro RS
dished pistons have a recess and don't offer as much compression as flat tops.
Old May 25, 2003 | 09:21 PM
flyway190's Avatar
That depends on what you intend to do with it. It's a replacement engine, not a racing engine.
Old May 26, 2003 | 12:15 AM
dennis6's Avatar
Car: 1991 Camaro RS
I wanted a 350 upgrade for my 305 that I could build later. I don't want to have to pull the pistons and replace them later.
Old May 26, 2003 | 01:00 AM
AJ_92RS's Avatar
Dished
Flat top w/ 4 valve reliefs
Flat top w/ 2 valve reliefs
Dome top (aka high top)
It's not so much about the power that is offered, it's compression ratio. Obviously the higher the compression ratio, the more power, but there is a line that has to be drawn for a street/strip car.
The dish pistons are usually sought after for supercharging or nitrous users to keep the compression ratio down.
Flat tops (either 2 or 4 valve reliefs) are used for street/strip cars to get the comp ratio up, but keep it low enough for pump gas.
Dome tops are normally used for strictly racing. The comp ratios usually are high enough that the engine will only run correctly with racing fuel.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
matthew911
Aug 12, 2015 09:38 AM
hokis
Aug 9, 2015 03:57 PM
antares57
Aug 6, 2015 07:47 AM
