emissions
Old May 27, 2003 | 07:32 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
emissions
I was thinking of swaping a 350 ho vortec moter into a camaro with tbi. im really not going to sup it up, but just add a couple of things (edlebrock intake, holley 670 tbi, accel ignition, headman headers, high flow cat, flowmaster exhust, and a k+n.)dose anyboby think I can pass emissions in caliaforna. thanks for all the help
Old May 27, 2003 | 09:16 PM
Aron213's Avatar
Car: 88 Iroc
The motor would have to be from the same year or newer, then every aftermarket piece would have to have a CARB number then I still doubt you would pass
Old May 27, 2003 | 10:16 PM
I was thinking the gm crate 350 HO that sells for like 2200. Its a newer motor for a older vhichle. everything else is 50 state leagl I belive. If that dosent work what will thanks for the help.
Old May 28, 2003 | 02:01 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
The GM crate engines are all designed for 1986 or earlier vehicles. Many of them are designed for 1973 and earlier vehicles. This is according to GM's site.
Old May 28, 2003 | 10:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Some things you need to understand:
1) There is no such thing as a "California emissions-legal" 3rd gen TBI 350.
2) The 350 HO engine is not emissions-legal in any car made after 1975.
3) If you want a 350 that you can get past the Smog *****, you're going to have to make it look exactly like the 305 in there now, with the exception of legal aftermarket parts (like upgraded ignition, exhaust, etc.). And make sure it runs as clean for the sniffer. And keep your mouth shut about it being a 350.
This is one engine you might be able to do the above with http://www.sdpc2000.com/cart.asp?act...id=128&pid=105
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
