355 buildup, oil clearances?
Old May 27, 2003 | 09:49 PM
StealthElephant's Avatar
Car: 87' Iroc
what should my oil clearances be? are important are they? should i be **** and afraid the engine is going to fail if they aren't perfect, or do they give a good bit? any measurements i should REALLY be meticulous on?
Old May 28, 2003 | 05:30 AM
ede's Avatar
ede
they should be what your manual says, go buy a manual. yes they should fall within spec, if not grind the crank or mix and match bearing shells with +.001 or -.001 shells, as long as you're standard. you should pay close attention to anythnig with a spec, measurement or torque.
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
BLK87Z
Sep 18, 2015 11:29 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
