350 from a blazer..
Old Jun 1, 2003 | 12:58 AM
mpitts77's Avatar
350 from a blazer..
79 to 81ish..anyone know anything about it? has a 2 barrell carb..gonna see if my 305 tbi manifold is gonna fit right..if not..im going carb. Any suggestion or anything i should be aware of? It's going into a 92 RS
Old Jun 1, 2003 | 07:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is one of the ultimate crap 350s. 929 cam, 882 or 624 heads, etc. Seems like a 350 2-barrel was "rated" at around 160 HP in those years. Even more weenie than your L03.
But as far as fitting, everything will bolt right up, with 3 exceptions: the angle of teh center 2 bolts on each side of the intake, the bolt pattern on the back of the crank, and the location of the oil dipstick (early dipstick totally incompatible with late model exhaust manifolds, you have to cure it with headers).
Old Jun 2, 2003 | 09:48 AM
mpitts77's Avatar
It's actually 3970014....350...70-76...2 or 4. So a 70's to 75 350 newly rebuilt
Old Jun 2, 2003 | 10:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's been rebuilt, then who knows what cam and heads it has.... it doesn't matter what block casting it is, as far as fitting or power output, they'll all be like I described. Although, probably 95% or more of all generic rebuilt motors get a 929 replica cam, it seems.
I seem to recall having a 78 Z28 that had that block casting in it. What a pig that car was. That motor was probably pretty similar to what yours would be if it was still stock. So I think Mortec might be slightly inaccurate about the years it was used in.
Old Jun 2, 2003 | 10:40 AM
mpitts77's Avatar
Yeah..don't really care to much on performance right now. As long as it can make a 3 hour trip..it's all gravy. After that it can sling every rod for all i care =D
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
