is zz4 worth the cash
Old Jun 7, 2003 | 05:05 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i have a 85 305 tpi project car that i have yanked the engine and trans out of and stripped the interior due to the normal t top leak all was junk. Car has bad auto trans go figure.. car has 77000 miles on it so it is a good project body. It is going to be a daily driver during warm months, maybe hit a few shows dependeing on what it comes out like. Question is i am thinking of keeping the tpi since we have emission testing here would the zz4 be a good choice or should i just get a 350 crate engine. either would be from gm i expect. just can't make up my mind. there is the slim chance that i may take up my buddies offer of his testing station and junk the computer and tpi, how much work is it to change over? wouldn't know where to start..
Ps the t top gasket replacement thread was a help in my new gasket job. been raining a week and car is bone dry inside..
Old Jun 8, 2003 | 07:46 PM
JeffW's Avatar
Engine: 305 tpi LB9
anyone have a suggestion?
i know this swap has been done so is it worth the zz4 or crate 350 ho good? computer or no computer. Alot of info on how to any end results?
Jeff
Old Jun 8, 2003 | 08:05 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I basically have a "ZZ4". It is a strong engine. If I were you to save money just buy the parts seperately and put together your engine. That way you end up with good parts but also not a beaten to the ground wallet Here is my "ZZ4" in the car...
Old Jun 8, 2003 | 08:42 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I have a ZZ4 in my car...been in there for close to 3 years now with not a single problem out of it. It is a strong running motor, but if you are looking for alot of power out of it, I would just buy the bottom end and get the heads elsewhere. This motor does pull hard, so ditch the stop tpi setup and go with a Miniram/Stealthram/Superram. I bought mine from Scoggin Dickey...excellent service. Check them out at www.sdpc2000.com
Old Jun 10, 2003 | 09:37 AM
tregnab's Avatar
89Z28, do you have any pics to share of your setup? I'd like to see it. Thanks.
Old Jun 10, 2003 | 05:40 PM
Dragroc's Avatar
I sure do, this pic was taken somewhere along the lines of 8 months ago.
Dragroc's Avatar
other side...
Old Jun 12, 2003 | 08:53 AM
tregnab's Avatar
That looks great, I'd like to move into that setup. What kind of headers are those? Also, are you running the stock distributor?
I've got some Edelbrock TES headers, but I took them out because they are such a pain in the butt. I'm looking for some stuff that fits closer now that will actually let you change the plugs in less than half a day.
Thanks for the info.
Old Jun 12, 2003 | 08:27 PM
Dragroc's Avatar
The headers are Hooker Competition shortys...as far as changing the plugs go, it's a snap; as far as y-pipe goes, forget it. I have had 2 different y-pipes fabbed up for it, and they pretty much both suck. Future purchases include Hooker Super-Comp long tubes. Other than the y-pipe issue, I have no prob whatsoever with the headers.
Yes it is the stock distributor. I have a Holley ignition module installed, with an MSD cap/rotor...also a Holley ignition box.
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
