305TBI to 350 TPI??
Old Jun 16, 2003 | 10:18 AM
mojo_jojoe4's Avatar
Car: 1991 Firebird Vert
Engine: 383 L98/LT-1
305TBI to 350 TPI??
I bought an early L98 with the MAF setup I think it is 87. I have a 91 Firebird with the 305 TBI. I talked to our local Hot Rod shop and they said I can use my existing ECM do to the fact that it can run the early TPI systems. Can I do this and just get an aftermarket chip for it? The motor does have the harness and everything. I already changed my fuel pump and that is what caused my car to start dying b/c I think too much fuel is getting to the 305. Any help is appreciated.
Old Jun 16, 2003 | 12:32 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Did you search the board? There is some wiring that need to be done to integrate the TPI system into your harness. As far as the I believe you can get by with changing the prom. However, I am not absolutely sure.
Old Jun 16, 2003 | 01:03 PM
Yes I have searched, I have the harness for the 350 TPI.
bamaboy0323
Sep 3, 2015 06:07 AM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
