350 HO or lt1?
Old Jun 23, 2003 | 02:26 PM
red305's Avatar
350 HO or lt1?
between swapping a zz4 or lt1, which is the least complicated. I'm not real real sure but wouldent the zz4 be easier? And wouldent everything else just "plug in"?
Old Jun 23, 2003 | 03:53 PM
Killogy's Avatar
Car: 87 Firebird Formula
Engine: 355
If you already have a carb setup the ZZ4 would be a breeze.
Old Jun 23, 2003 | 05:10 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
The ZZ4 and the 350HO are two different crate motors. However for the money, the 350HO is a far better deal in my opinion (costs way, way less). The vortec heads that come on the 350HO flow way better than the aluminum vorvette heads as well. I ran 12.93@106 with my 350HO in stock form.
Old Jun 23, 2003 | 08:14 PM
red305's Avatar
ok, so then the HO, which is fuel injected I'm assuming. simple and straightforward install? With instructions and everything?:lala:
Old Jun 23, 2003 | 08:49 PM
The deluxe comes carbed and the base crate engine comes without intake/carb/distributor. If it were me, I would go carb to save yourself some headaches.
Old Jun 23, 2003 | 08:52 PM
red305's Avatar
how many headaches are we looking at?
Old Jun 23, 2003 | 08:58 PM
More money, more wiring, depending on what type of F.I. you go with custom chip burning, more tuning, possibly the need for dyno time to dial it in.
A carb setup, properly dialed in, can make just as much power as fuel injection at a fraction of the cost.
Old Jun 23, 2003 | 09:04 PM
red305's Avatar
guess I was wrong for thinking this was gonna be easy, thanks...
Old Jun 23, 2003 | 11:01 PM
Don't get me wrong, there are a ton of people on here that can help you with fuel injection, I am just telling you that if you slap a carb on that motor you wont be dissapointed .
Old Jun 24, 2003 | 02:03 AM
IROCJTOWN's Avatar
It depends on what he wants his car to be like. A carb has a couple disadvantages to a FI setup. If he just wants to romp around on the 1/4 mile and dosn't mind learning to tune the carb then he won't be dissapointed.
Old Jun 24, 2003 | 09:52 AM
red305's Avatar
nah I like FI, I guess easiest thing to do for now is find a third gen z28 350 and rebuild that for a swap later on.
Old Jun 24, 2003 | 12:44 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
If your state requires emissions testing go FI. If your car is already equiped with TBI or TPI you already have a good baseline.
Old Jun 25, 2003 | 09:19 PM
1fastformula's Avatar
Car: 1989 Formula 350 / 2000 Lightning
Engine: GM HO 350 Crate (Vortec headed w/TPI) / SC 5.4 330
Transmission: Rebuilt 700R4 (Raptor Rebuild Kit)
My ***!!!!! Explain stock form for me and what do you have the engine in........ I definitely got to get to the track. I do not think I am running that good, but mid 13's should be conservative for guessing.
Later
Old Jun 26, 2003 | 01:27 AM
Later
It is in a thirdgen, 1982 Camaro that weighed 3100 without driver at the time. I meant the motor was in stock form. It had a performer intake, a demon 650 carb (that was the ticket, worth a full second over my 600 edelbrock), msd pro billet distributor, msd blaster 2 coil, accel wires, electric fan, hedman ellite ceramic coated headers, dual exhaust, a turbo 350 and a 3000 hughes pro street stall with 3.73's and posi.
As for now, I have yet to get this combo to hook up but I have added:
Comp Cams Extreme Energy 274 Cam (230/236 .487/.490)
KMotion Valve Springs (no machine work required)
Pinned studs
Professional Porting and polishing of my vortec heads
Shim gaskets
Shaved heads 4cc (giving 10.06:1 compression)
Super Victor for Vortec heads
Carb Jetting
Out of that setup i have managed a tractionless 12.74@108.97 mph. I am hoping to have it to 110mph sometime soon, we'll see.
I think your TPI, even with the aftermarket base, and any additional weight you have will hold your car back from reaching 12's.
Seth
Old Jun 27, 2003 | 10:51 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
hows ur tranny and rear holding up?
Old Oct 23, 2003 | 01:36 AM
dennis6's Avatar
Car: 1991 Camaro RS
Was the demon a Vac or Mechanical secondary?
Old Oct 23, 2003 | 10:11 AM
They are holding up awesome. Turbo 350 with a 3000 stall and 7.5" 10 bolt with an SLP posi, 28 spline axles and richmond street 3.73 gears.
New best is a 12.45 @ 110 on a 1.95 60 foot (no traction, still on street tires). I have 1.82 60 footed before, I know it will 1.7 now with the tuneup i just gave it, so on tires it probably would have gone in the 12.1X's.
Seth
Old Oct 23, 2003 | 10:12 AM
Mechanical
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
