Jul 14, 2003 | 10:53 AM
What mods will be needed on the TPI for a mild 400? I've seen a few things that have been done but bottom line what will I NEED to do?
Reply 0
Jul 14, 2003 | 05:46 PM
Re: Tpi 400
Quote:
you NEED to find a way to shove more air into that motor.
what you dont need is long runners for even more TQ.
so my suggestion would be a diffrent intake..
converted LT1 or miniram would be ideal.
Reply 0
Jul 15, 2003 | 05:37 AM
If you still wish to use the TPI intake setup, I would recommend a definite port job on it, and probably making a siamese port job out of it. This will probably give you sufficient air for a mild 400. Good luck with it.
Reply 0
Subscribe
