LT1 Starter solenoid
Old Jul 16, 2003 | 11:46 AM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Can someone post the correct wiring for the starter/starter solenoid? A friend of mine wired his backwards on his jeep and blew the starter motor....I can't afford a new starter motor just yet lol
Old Jul 16, 2003 | 11:58 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
The large bolt is where the positive battery lead goes to(large wire). This is also where I added a wire to for the PCM constant 12v. The smaller one is for the purple cranking wire. You can't really screw the wires up on this thing.
Old Jul 16, 2003 | 12:05 PM
Corry's Avatar
Car: 1987 Trans Am
what about all the fusible links? I thought the starter solenoid served as a power distribution point. Do they just go where the battery goes?
Old Jul 16, 2003 | 12:10 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
I eliminated the fusible links. The power for the PCM I took off the starter solenoid constant 12v wire. For the rest of the car...I ran a wire from the battery to the c100 connector wires that needed a constant 12v.
Old Jul 16, 2003 | 12:11 PM
Corry's Avatar
Car: 1987 Trans Am
interesting.....I will probably keep them for now because I am in a hurry, but I'll just run 'em to the battery...
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
