V6 to V8 tach fix please!!!
Old Jul 17, 2003 | 05:04 PM
andys86ta's Avatar
Car: 1986 trans am
Engine: 300hp 355cu. inch
Transmission: 350 turbo with shift kit and ratchet shifter
I bought an 86 firebird with a 350 engine but was originaly a V6 car. I need a way to calibrate my tach so it will read even close to what it should. I have read they can do it with the s-truck engine swap but I can't find facts. The car has a really nice guage package so I would like to keep it. Thanks.
Old Jul 17, 2003 | 09:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You need a V8 tach.
Old Jul 18, 2003 | 06:09 PM
Damon's Avatar
My brother has recalibrated tachs to work with V8s that never had them- even a weirdo rotatry engine tach in an RX-7 that got a V8 transplant. It's basically at it's heart a change of a single resistor inside the tach. Knowing which one and how much to change it, though, is the real trick. I guess being an electrical engineer like he is helps.
Old Jul 19, 2003 | 08:51 PM
CaddiBird's Avatar
Car: 89 base 'Bird
Engine: 507ci Caddy
Transmission: BOP TH400
If you look at some of the Toyota truck 4x4 sites they swap in 4.3's and 350's in em and what they do is wire a pot onto the motor of the tach. Then you adjust it to read correctly by hooking up a multimeter to the engine or using another tach. Do a search for it on google and you should find it. I've did it to my cluster but I havn't gotten a chance to try it(no engine in car ) If I remember right the pot was either a 10k or 5k ohm linear taper. I got it from radio shack.
Old Aug 6, 2003 | 01:18 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
all the rotary tach should be is a standard 4 cyl tach
thats it
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
86maro_252
Oct 10, 2015 06:52 PM
BWilcox
Sep 20, 2015 12:19 PM
TrevinE
Sep 14, 2015 03:20 PM
