throttle cable problem!!!
Old Jul 27, 2003 | 08:40 AM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
throttle cable problem!!! to short
well I switched from a 2.8 to a 350 carb I reused the stock cable and when the pedal is pressed to the floor it only opens the first set of butterflies and maybe a crack of the secondaries. What can I do to solve this problem. any help would be appreciated.
Old Jul 30, 2003 | 07:27 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Vacuum Secondaries
You're looking for an opening of the secondaries while the car is running, right?
Idle the car, and have a friend observe the CARB. Floor it.... and the secondaries should open right up within a second afterward. If they don't, there either set WAY too tight, or the vacuum line leading to it is leaky, or missing.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
