v6-v8 swap
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
v6-v8 swap
just need some info on a v6 3.1 to 350 tpi setup.i wanna put a 350 tpi in a 92 firebird. what will i need to do as far as ecm and wiring ?
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Here is an exerpt from the FAQ on the main page that applies to you.
Q: Does it pay to swap my 4 or 6 cylinder engine for an 8 cylinder?
A: First of all, you have to decide if you are going to keep the computer system. It's a bigger hassle if you do. Your best bet is to go to a junkyard or find someone who is parting out a V8 Camaro/Firebird, and pull as many parts as possible off the same car. You will need brackets (i.e. alternator, AC, smog pump, and power steering pump - save the bolts too), AC hoses, and Pulleys. You will also need new rubber motor mounts (about $20 at local parts store) and the engine side brackets that these mounts bolt to. Make sure you get the engine side motor mount brackets from a Camaro or Firebird as they are a little shallower and are needed to get the engine to sit low enough in the bay. The holes for the motor mounts are already in your crossmember. You will also need to get the engine fan and fan shroud (junkyard or new - your choice). You will need to buy a starter, water pump, and probably a power steering pump (get thses from a junkyard as they're almost always still good). You'll need a V8 HEI distributor. An ACCEL rebuilt HEI works great and costs less than $150.00. And of course plugs and wires. Assuming an automatic tranny, you will need a new tranny since the bellhousing bolt pattern is different on the V8 car from the 4 and 6 cylinders. A Turbo 350 will bolt right in with B&M's $75.00 conversion kit. It just lets you hook up the torque arm, but you'll lose overdrive. Take a polaroid camera to the junkyard, and you should be able to figure all this stuff out. Finally, you will probably have to change the front coil springs. I know this sounds like a ton of work (especially since it doesn't even include what you have to buy to assemble the engine), but this swap is really a piece of cake - everything drops in like it was supposed to be there. At the very least, assemble all the components you'll need (build the motor on an engine stand over a few months with all accessories and brackets), and have someone drop it in for you. A shop would charge you an arm and a leg if they had to scrounge all this stuff up themselves.
One piece of advise we often give on this site especially for the beginner is this. Sell your car and buy a V-8 especially if you live someplace where the smog laws are strict like California. It's harsh but it's actually the easiest thing to do.
Or you can buy a V-8 car and swap parts from the one you want to scrap to the one you want to keep. Hope this helps.
Hello, Michael
Aug 20, 2015 03:19 PM
