Help 2.8 to 5.0 swap
Old Jul 29, 2003 | 04:22 PM
1mean99grandam's Avatar
I'm sure it's been written here already - I've done a search, but I haven't found the answers I'm looking for.
I have a 1987 Firebird with the 2.8L. I want to go to the 5.0. I would do the 5.7 but I really want this to be a stick. Seeing as how this will be my first swap - I want it to be a little easy. Also, I don't have a garage.
I have found the 305, the manual tranny for it and computer harness for $600. All from the same car, all in really nice shape. 1988 Camaro. And the dash from a 1987 5.0 Firebird
First, how hard is it going to be to get the 2.8 out?
2nd, what can I use off the 2.8 for the 5.0?
3rd, what can I throw out? Like A/C and so on.
Still has to pass Cali/NY smog laws and be road legal.
I'm not out to make a monster of a car. Just something that looks good, runs good and is better than this 2.8 I have right now. Later, I will make it a BEAST. I sort of want to do one simple engine swap as a learning experience. I'd like to keep this experience around $1000.
Oh, and is there a step by step book on GM swapping? Sounds lame, but I really want to do this myself and do it right.
Old Jul 30, 2003 | 07:49 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Actually most of the questions you did ask come up all the time. But for simplicity sake I will answer what I can.
With an engine hoist and the tools it's not hard at all.
Not much. You need new front springs, motor mounts, fuel components, computer, flywheel, wiring accessory brackets, belts.
I am not sure I understand what you are asking.
This can be a problem. I have no idea what the engine swap laws are out there. But you can always find some shady guy to pass you anyway. A couple 20's go along way.
Swapping from a 2.8 to a 5.0 or 5.7 can be done. Best thing to do is either sell your car and buy a V-8 car, or buy a V-8 car and swap your 2.8 cars interior and body stuff over to the V-8 car.
Or buy a complete V-8 car and pull everything you need off of it.
To clear up one other thing there are people on the board here that are using the T-5 with the 350. They just didn't come from the factory that way. They can hold up. You just shouldn't be too rough on it.
If you want a strong manual transmission you should go with a T-56. However the auto to manual swap is a pain if you have never done this kind of work before.
Another bonus is that if you buy a V-8 car and use your V-6 car to make it nice or use the money from your V-6 car to buy and fix some of the V-8 car you can stay emissions legal. Hope this helps.
Old Jul 30, 2003 | 08:28 PM
wow. thanks.
Cleotiz
Jan 6, 2018 08:56 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
