2.8 to 454 swap
Old Aug 2, 2003 | 12:00 PM
Sebastian's Avatar
2.8 to 454 swap
I have recently purchased an '83 Camaro with a 2.8 v6 and i'm wondering what all would be involved if i put a big block in. My goal is to make this car into a weekend dragger and a street racer, i have had luck doing this with my '71 442. I was looking to buy a Nova but i saw this car and just couldn't pass it up. I'm not used to working with cars like these so any and all info. would be nice.
Old Aug 2, 2003 | 06:00 PM
chev496's Avatar
Car: 90 RS
Engine: 8 holes
Transmission: Quickest, quicker, quick...
Axle/Gears: 10 bolt, 3.73
I bought a 1990 Camaro about a month ago with a blown tranny and the 3.1 v6 planning on putting a 496 big block in it. Well, from what i have found and i still havent even putthe engine in it yet, this is what i have had to do.
REmove tranny and and find a nice tranny that will work.( a 700 r4 outta a newer style tuck should hold up fine)
Sub frame connectors
Remove complete wireing harness, and computer, then seperate the ones wires for hte garuges and for hte computer.
remove wiper motor, oil air filter, and all emisions.
re work stock tach somehow.
fidn exhuast manifolds that will fit or buy headers.
Make sure your rear end will hold the abuse.
I know i did more, but the engine should drop in in about 2 weeks, just waiting for my heads to get done and the machine shop and she will be on the road, hopefully.
Old Aug 4, 2003 | 02:37 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The FIRST thing you want to do if get a V8 donor car... with as many of the V8-specific parts as possible. Something like a T/A, Z28 or an IROC would be good.
One other thing that isn't necessary to bolt the engine in, but is a definite MUST for a torquey 454 is sub-frame connectors... without them, that big block with twist that poor Camaro's body like a pretzel
Old Aug 31, 2003 | 11:11 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
What do you have to do about motor mounts? Id like to see some pictures of thirdgens with big blocks...does it fit without cutting anything?
Old Sep 1, 2003 | 03:28 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
a bit of cutting ...the lower control arm for the Hooker 2226..USe the stock SBC mounts
Daz
Old Sep 3, 2003 | 10:18 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
It all on my page at www.koolmeister.com
Fast355
Dec 2, 2016 06:33 PM
E Rod
Aug 28, 2015 05:17 AM
sreZ28
Aug 14, 2015 07:48 PM
Kaweh
Aug 9, 2015 02:54 PM
cRoe4
Aug 7, 2015 08:46 PM
