383 flexplate questions
Old Aug 11, 2003 | 03:17 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I'm having trouble nailing down which flexplate everyone is using for a 2 piece rear seal .030 over 350 block/400 crank 383 with the 700R4 trans. What is the tooth count needed for the new flex plate??? The engine will be externally balanced to the new 6" rod/.030 piston/Scatt stroker crank (350 mains) rotating assembly with a stock 400 type damper from Summit or Jegs. Part numbers and/or links helpful.
Old Aug 12, 2003 | 11:18 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't seen anything but a 168-tooth, 2-piece externally-balanced flexplate. But, I haven't seen everything.
Seem to hear a lot of complaints about starters when going to 168-tooth, but a mini seems to solve that issue.
Old Aug 12, 2003 | 11:35 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You can put a balance plate on a stock flywheel and use it.
Old Aug 12, 2003 | 12:08 PM
bnoon's Avatar
The balance plate idea I like, but I haven't seen one for the 700R4 trans listed. If the 700R4 takes the same standard 168 or 153 tooth flexplates with the TH350/TH400 stall patterns, and the early two piece rear main crank pattern, then I would be fine. All of which I've been able to find listing the three speed transmissions as applications, but nothing about the 700R4.
Old Aug 12, 2003 | 07:59 PM
83crossfireZ28's Avatar
i just used the stock 400 flexplate when i put my 400 in... had to go to a staggered bolt starter to make it work, but no problems bolting up to my 700r4... we got like 7 of those flexplates laying around...
Old Aug 16, 2003 | 08:49 PM
Todds1987iroc's Avatar
If you have your rotating assembly balance, the balancer should be able to use what ever plate you plan on using with your engine. A good engine shop will balance your crank with the dampner and plate attached to the crank. This is how Ohio Crankshaft Balanced mine for the 383 in my '69 camaro.
84z96L31vortec
Aug 20, 2017 12:16 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
