86 2.8L to 91 305 swap what do i need to do?
Old Aug 14, 2003 | 03:58 AM
stiers's Avatar
Subject says it all. I have a '91 RS that was run over by a semi... body is trashed but somehow the engine transmission and everything is good. We drove it up the trailer so we know it works still. What I need to know is other than removing all the wiring, ECM, VATS, and anything electrical atatched to the Camaro is there anything we need to do to the bird to get the engine in there? Keep in mind that I have the entire '91 to work from. All that is bad on it is body pannels. I will be swaping the engine, transmission and driveshaft from the '91. Will I need to do any fabrication to the Firebird to make this work as far as welding or cutting anything?
Old Aug 14, 2003 | 06:10 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Often discussed.
Everything you mentioned needs to be changed except the driveshaft (they're identical). And everything that is attached to or supporting the engine like the hoses, belts, exhaust; not sure but probably some fuel things (in-tank fuel pumps operate at different pressures - just change the tanks). Nothing needs to be fabricated, but you'll wonder as you change those engine mounts attached to the front crossmember. You might just consider changing the crossmembers over with the engine attached, since the nuts are about impossible to get to for those engine mounts, and the springs & sway bar should be changed, anyway.
Change the tach. Except 'Maro & 'Bird tachs aren't the same.
Hope you love this 'Bird before you get started on this. You'll hate it while you're going through this process. In a couple of years you'll probably like it again - well, maybe sooner, you'll like the new power.
xkingcodex
Feb 12, 2020 07:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
gwade12
Aug 8, 2015 08:17 AM
