350 engine build up
Old Aug 18, 2003 | 10:41 AM
TallWhiteGuy's Avatar
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
350 engine build up
Okay now i have some questions. First could I built up a 350 and use my tbi induction from my 305 and bolt on there and it would run or is there some other way to do this? Because i saw sombody that may have down this but not sure OR are they different ways of doing this because i want to try to keep the tbi trying not to make things not so difficult. Any help would be appreciated.
Old Aug 19, 2003 | 01:49 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Yes you can swap the 305 tbi onto a 350, but you will need to upgrade to 350 injectors and get a ecm for a 350. While you're in there I suggest you do the ultimate tbi mods as well.
Old Aug 27, 2003 | 10:46 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
**** it. Get a carb.
Old Aug 28, 2003 | 02:26 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I think the TBI and TPI injectors are different. And since the TBI system never came on a 350 it is unlikely that it could feed a 350. I could be wrong. That wouldn't be unusual.
Actually I am wrong. TBI came on the truck 350's until 1996. So you could get 350TBI injectors off of a truck 350.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
