305tbi>zz4
Old Aug 20, 2003 | 09:34 PM
BADBIRD009's Avatar
305tbi>zz4
anyone know if the starter and/or altanater will work with a zz4 crate enigine? i will be using the flywheel that came with the zz4.
jason
Old Aug 20, 2003 | 10:18 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
The ZZ4 comes with a flex plate if I'm not mistaken, and if you use it I'm 90% sure the starter will work. The alternator and other accessories will definitely work.
Old Aug 21, 2003 | 09:00 AM
BADBIRD009's Avatar
hey fbird88 how did you get your stock tbi fuel pump to work? i talked to jegs and they told me i need a new feul pump, cuz if i used the stock one then i would have to run an afpr and run a return line to the tank to use the stock one and at that point i would have done more work and and money than just puttin in a new pump, and on top of that it would only be a temperary fix, is this true?
j
Old Aug 21, 2003 | 10:45 AM
Fbird88's Avatar
Car: 1988 Firebird
Axle/Gears: :(
j
It'll last until the stock pump dies. It could last 5 years or 5 days. It's more work to run a new fuel pump than to put in an AFPR. The tank already has a return line so you just conect it to the AFPR. And it will also cost less than a new pump. In the long run, it may or may not be the best solution, but its the simplest. I always keep at least 1/4 tank of gas because its old and needs to run cool. When it dies, I'll probably drop the tank and replace it with another stock pump.
Old Aug 22, 2003 | 03:45 PM
rallysportridin's Avatar
Car: 1989 Camaro RS
Engine: 305 tbi
Transmission: 5 Speed
is it possible to swap the 305 tbi with the zz4 i asked a couple sights like the scoggin dicky, jegs and i think i asked the gmpp site, if it is possible i would like to know thanks guys
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
