the zz4 is in!!!
Old Sep 8, 2003 | 10:26 AM
BADBIRD009's Avatar
the zz4 is in!!!
zz4 is in and all went smooth.
special thanks to danny aka abird4u2nv1 :hail:
Old Sep 9, 2003 | 12:19 AM
Z_Ghost's Avatar
Cool, let us know what it runs in the 1/4 with the carb, I just got finished putting a ZZ4 with a SuperRam on it in my car.
Old Sep 9, 2003 | 12:06 PM
BADBIRD009's Avatar
hey zghost did you use your factory accesory brackets with your zz4? im not gonna use the ac but i am going to use the tensioner bracket that the ac goes onto for now. the holes dont line up with that bracket at all. any ideas?
the altenater bracket doesnt line up either but i am going to grind a little part of it out to clear the water pump.
Old Sep 9, 2003 | 02:28 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Great lookin motor in thereThanx for the shout out!
Anytime man. just wanna hear that badboy run
Old Sep 13, 2003 | 11:31 PM
Z_Ghost's Avatar
I had to drill and tap one hole in the passenger side head and grind that bracket to clear the water pump. The driver side fit fine like it was.
What I did was bolt the bracket to the block and to were it matched up with the head, then the one hole that was missing I used the bracket as a guild to drill the hole. Just go as deep as the other holes in the head and then tap it.
lt500r55
Sep 1, 2021 01:30 PM
italiano67
Sep 22, 2015 08:42 AM
anesthes
Sep 18, 2015 12:34 PM
Magman
Sep 13, 2015 12:14 AM
italiano67
Aug 31, 2015 06:04 PM
