Six To Grate 8
Old Sep 12, 2003 | 09:29 PM
firefrombelow's Avatar
Six To Grate 8
My dad has a 91 bird with a 3.1 v6, but we have a 350 for it. We want the motor to get it to push at least 450hp. We already have a forged crank, and pretty much everything else will be replaced. We will mainly just use the block. We are gonna stroke it to a 383. I suggested the vortec heads for $250 a piece, but im not sure. My uncle is gonna do all head work and block machining. Plus .030 bore. Any suggestions or part numbers would be great.
Thanks Alot
Old Sep 12, 2003 | 10:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Get a blower
Old Sep 12, 2003 | 10:12 PM
Has to be N/A Thanks anyway
Old Sep 12, 2003 | 11:57 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You could go with pro topline heads. They are good for more HP than vortecs.
Old Sep 13, 2003 | 02:05 AM
Air_Adam's Avatar
1.75" headers are an absolute must for that much power, as well as aluminum heads (i'll let others suggest which set) so you can go to about 11:1 compression safely on pump gas. You'll probably want to figure out how to route a set of true dual exhausts too, at least 2.5".
If you can put up with the adjustment routine, I'd suggest solid lifters too, because you will probably need a fairly radical cam to make that much power.
I'd also suggest a good, single plane intake manifold (Edelbrock?) and a 750-800 cfm Holley double pumper carb.
It would probably be a good idea to invest in a good, high performance radiator like one from Be Cool or Griffin, as well as an engine oil cooler.
Oh yea, that reminds me... synthetic engine oil is known to free up a few ft-lbs and hp too
Just my $0.02
Old Sep 13, 2003 | 04:03 AM
HIBERNIS's Avatar
If money is not an issue, Id get AFR heads with their 195cc 2.02/1.60 head or the 210cc 2.08/1.60 head starting at around $1200 the pair, fully assembled.
Old Sep 14, 2003 | 08:06 AM
Cam84358's Avatar
Car: 84 Camaro
Engine: v6 to v8 swap 357ci chevy
Transmission: TCI Turbo 350
Its hard to beat the vortec heads on price and they are good
from everything I have read.Several magazines have made 400 hp with 350ci engines.
Jote4805
Aug 25, 2015 06:11 PM
Danno
Apr 7, 2002 01:23 PM
JETHROIROC
Sep 5, 2001 12:03 AM
RARE-ROC-Z
Car Audio
Jul 23, 2001 01:49 AM
