buidling 350 need tips and ideas?!!
Old Sep 15, 2003 | 08:51 AM
chevycamaro1984's Avatar
thing i am trying to get at i need help with getting the parts togeather to make 400+ hp so far i got
350 bore 30. over
heads-Pro TopLINE 220cc IRON SBC Chevy heads, these have a 64cc and 2.02/1.60 valves
double rollor timing chain
not sure about Cam
edelbrock performer rpm high rise
carb not sure
thinking about 12-1 compression
this will be in my camaro for the strip
TRYING TO MAKE 400++ hp
gonna be a drag car 1984 camaro gonna get cage new rears tranny frame susports everything
Old Sep 15, 2003 | 05:43 PM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
strip only car:
should use single plane intake like victor (perf intake is good for street/strip)
alum. roller rockers
750-850 holley 4150 mec. secondaries carb(mod. 50cc acc pump)
high stall and steep gears if auto
Old Sep 16, 2003 | 02:33 AM
BILLY SMITH's Avatar
Re: buidling 350 need tips and ideas?!!
350 bore 30. over
not sure about Cam
carb not sure
i would say first get you a victor jr. single plane........and at least an 850cfm mech. sec. holley......heads are a good choice they have good flow numbers...as for as cam i suggest a competition cams #12-609-5 ...(285B6) it has 250 deg int at .050....260 deg exh. at .050 ..intake valve lift is .532.....exhaust vavle lift is .555 with a 106 deg. lobe sep. angle this is a very good cam for makin power get you a 3500 converter and a 350 turbo and 3.73 that will get you movin
Old Sep 17, 2003 | 11:37 AM
building 350
thanx guys for the info what compression ratio??
Old Sep 17, 2003 | 01:26 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No particular excuse for a single plane these days. But, if stall is high enough, probably won't hurt anything.
Might as well go 383 while you're at it. More torque, more power, at lower RPMs (helps things like valve train last longer).
Compression ratio depends upon what kind of gas you're willing to burn. If you want to stick with pump gas, don't go above 11:1. If you're willing to buy racing gas, then 12:1 is fine.
Talk to the cam manufacturers about their recommendations. They'll get you on the right track. In my opinion, you build the whole engine around the cam, so get that right before you start buying any of the rest of the pieces.
Old Sep 17, 2003 | 09:58 PM
cam
yeah i will be running race fuel so it don't matter would 12-1 compression be good enough or little higher octane is 115 so 2 buckz a gallon let me know info with all that stuff what hp we looking at??
neekolzun
Aug 24, 2015 04:59 PM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Jlanz55
Aug 17, 2015 07:15 AM
